AIO V1.50b4
Neu Test-Version:
AIO V1.50b4
Ich warte auf Feedback ...
Changelog:
### V1.50 - 2016-07-16
_**CHANGES/NEWS:**_
- Tried to integrate an automatic update function (hope it works on every Windows version out there)
* i use aria2 (
https://aria2.github.io ) for that, so if your firewall complains aria2c.exe, you have to allow it
* how does this work: file 'AIO_update.txt' will be downloaded from google drive, evaluated and if there is an update, a zip file with changes will be downlaoded and unzipped automatically
* i hope, this will work for version 1.51 ...
- After select 'individual background image' you now can choose from one of 80 images in choose\more_background-images folder
* simply double-click on the file-name of the image and it will be used, if you just close the window, the original background will be used
* if you want to use your own background image you can copy it into the folder choose\more_background-images
* unfortunately I can't show thumbnails of the images, so an explorer window showing the thumbnails for folder 'more_background-images' will be opened automatically
- Added color-themes for AIO: set colortheme=1 (old theme) or 2 or 3 (actually set) in line 20 of choose.cmd or change to values by yourself
- Seperated changelog (now CHANGELOG.txt) from AIO_README (now README.txt), *.md files will be renamed to *.txt at first start of AIO
- Language popup window will now be shown only at first start of AIO (and after updates)
- Background Rotator should work now
* try this to make your own backgrounds very easy: PhotoJoiner.net - Join multiple photos together.
- Added new FW 58.00.250A- NA (from new CX-9) for all tweaks (thanks to houset from mazda3revolution.com for the necessary files)
* modified installer/uninstaller for speedcam-patch (thanks to Modfreakz), pause_on_mute, no_more_disclaimer, list_loop and order_of_audio_source_list, all other files are the same
- Update to speedometer 4.4:
* added language French (thanks to drean179 and Regg001 from mazda3revolution.com)
* optional show the vehicle speed instead of the gps speed in the small speedometer (thanks to vic_bam85)
* added numeric output of top engine speed in right table
* changed statusbar speedometer toggling of gps altitude/direction only active if full size app is closed
- Updated all tools by Modfreaks in folder choose\tools\JCI_NNG_Tool
- Added Croatian for safety-warning-reverse-camera
- Fixed speedcam-patch installer for 56.00.100A-ADR, 56.00.230A-ADR and 56.00.401A-JP, data.zip wasn't modified correctly
- Fixed speedcam-patch uninstaller for 56.00.513C-ADR, I hope the NAV app will start again after uninstalling, please report back
- Added 58.00.250A-AN for speedcam-patch (thanks to GrilloA from mazda3revolution.com for the files), please report, if it works
- Position of AIO window corrected for two monitor systems, should now be just left of center.
- Added speedcam.txt for Turkey (thanks to volcano2K from mazda3revolution.com)
- Update for Turkish language (thanks to volcano2K from mazda3revolution.com)
